DoctorA's avatar
DoctorA
Luminary
Nov 23, 2019
password doesn't work for mobile app
I clean installed the orbi app on my iphone Xs Max but my wifi password showing on my desktop NG GUI is not working in the last step "Log In to Your Orbi". Showing: user name admin Password(Defau...
  • Bandito's avatar
    Bandito
    Dec 10, 2019
    What password is it requesting?  The WiFi password or the admin password?
    Since it started after you added in the RBS50 satellite, have you tried using the password that you originally used on the RBK50 system?  You may also want to remove the RBS50 satellite and try again.
