Loul01
Sep 19, 2021Aspirant
Pb couverture wifi avec satelittes orbi
Bonjour, j'ai installé un routeur RBR850 ainsi que 3 satellites dont 2 cablés en RJ45 dans notre maison. Nous n'avons que très peu de réseau à l'étage et au sous-sol, malgré la présence de satelli...
- Oct 04, 2021
Let me first thank you for the provided support.
I solved my issue by noticing the firmware was very old and heterogeneous across Satelittes and Routeur. I upgraded each componenent one by one manually, starting with the Satelittes then reseted the routeur and reconfigured the network.
Now this is properly recognizing my devices on each Satelitte and Routeur
Sep 20, 2021Guru - Experienced User
Can you try reducing the distance in between the RBR and the Kitchen RBS? Turn OFF the other two RBS leaving the kitchen RBS on. Keep checking the status as you move the kitchen RBS around or a bit closer.
Is WMM enabled Under Advanced Tab/Advanced Settings/Wireless Settings on the RBR?
Loul01
Oct 04, 2021Aspirant
- FURRYe38Oct 05, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
