Roger10
Sep 04, 2020Follower
PC Doesn't Detect ORBI RBR750 Wifi
My PC sees every WiFi signal available except the ORBI RBR750. All my other devices see the ORBI signal and connect easily. It should be pretty simple. Any ideas?
minesweeper
Sep 04, 2020Aspirant
PC driver may need an update. You can also try disabling 11ax in Orbi and see if it helps.
