Chuck_M
Oct 13, 2020Mentor
Phantom Satellite On Phone App
My RBR850 with 1 x RBS850 and 2 x RBR-50s (hardwired) is working great. However.... On the android Orbi app I clicked on Network Diagram and got the expected "tree" of the router and three sa...
- Oct 14, 2020
I did a factory reset of the RBR850... and set it up from scratch. Added RBS850 and then 2 x RBS50s.
The phantom satellite is gone and everything is working great.
Wasn't the app, was the device itself.
Thanks to all for recommendations.
Oct 13, 2020Guru - Experienced User
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
- Chuck_MOct 13, 2020Mentor
This issue is not centric to the app, but somewhere between Orbi and the app. If anyone has any ideas, I am listening.
Thanks for the assist.
- FURRYe38Oct 13, 2020Guru - Experienced User
- Chuck_MOct 14, 2020Mentor
Thanks... that is close to issue, but not exactly. Phantom satellite does not show in diagram, has no techinical data (IP, Mac, etc).
I will (sadly) do a full reset without backup restoration this evening and see if that clears it up -- which I am thinking it will.
Have already uninstalled and reinstalled app -- which had no effect on the issue which remains.
Will advise how it turns out.
