Chuck_M's avatar
Chuck_M
Mentor
Oct 13, 2020
Phantom Satellite On Phone App
My RBR850 with 1 x RBS850 and 2 x RBR-50s (hardwired) is working great.   However....   On the android Orbi app I clicked on Network Diagram and got the expected "tree" of the router and three sa...
  • Chuck_M's avatar
    Chuck_M
    Oct 14, 2020
    I did a factory reset of the RBR850...  and set it up from scratch.  Added RBS850 and then 2 x RBS50s.
    The phantom satellite is gone and everything is working great.
    Wasn't the app, was the device itself.
    Thanks to all for recommendations.
