Yoski1971
Apr 02, 2023Aspirant
Philips Hue drops my Wifi internet from 650Mbs to 95Mbs
I have a Virgin Media Gigabit router and a Netgear RBR350 Router with 3 Satellites - Everything works perfect when i disconnect the philips hue beidge - as soon as i plug it it the Wi-Fi on the Netge...
Yoski1971
Thanks for all that information.
The problem only happens when I plug in the Philips Hue Bridge as soon as I disconnect the ethernet from the Philips bridge speeds rocket up.
I will try the channel changing and try moving it away from the router and I might change the ethernet lead also.
Thanks for all your information
Mikey94025
Apr 02, 2023Hero
How is your Hue bridge network setup? I'm wondering if it's creating an IP conflict when it joins your Orbi home network. (Perhaps you set it up with a static IP with your old router and now it conflicts with the new Orbi device IP assignment)
- Use the Hue app to examine and set the network configuration. Try DHCP first.
- If that doesn't work, factory reset your Hue bridge and set it up again. I know this will be a little painful but it will probably fix your current networking issue.
