CharlesWK
Dec 29, 2023Aspirant
Phone connectivity issues with Orbi RBR/s750
I have an Oribi RBR 750 with two RBS satellites. I am having connection issues with my Samsung Note 10+. I will have a good connection but at some point it will indicate no internet while still con...
CrimpOn
Dec 29, 2023Guru - Experienced User
Intermittent issues are the very devil to diagnose.
- The Samsung Note 10+ never recovers by itself?
- Is there a user forum for the Note 10+? If customers are reporting similar issues with other brands of WiFi, then it might be a "Samsung problem."
- Some Samsung devices display the signal strength of every available WiFi access point with the same SSID?
- When I click on the little "gear" symbol, my Samsung Galaxy Tab S6 Lite shows the signal strength of all eight access points that are broadcasting the primary WiFi SSID (router + 3 satellites = 4. times two radios each (2.4G and 5G) = đ
If there is another access point with a strength very close to the one that the Note 10+ has selected, then it might be interesting to experiment with reducing the Transmit Power of the 5G WiFi signal. This is on the Orbi web interface, Advanced Menu, under Advanced WiFi Settings. Personally, I keep everything blasting away at 100% power, but everything seems to be working so, "if it ain't broke, don't fix it!"
