CharlesWK
Dec 29, 2023Aspirant
Phone connectivity issues with Orbi RBR/s750
I have an Oribi RBR 750 with two RBS satellites. I am having connection issues with my Samsung Note 10+. I will have a good connection but at some point it will indicate no internet while still con...
CharlesWK
Jan 23, 2024Aspirant
It turned out to be a wonky switch used for certain hardwired devices. Replacing it with a new one solved all the issues I was having.
Jan 24, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
