ALEUNG
Mar 25, 2021Aspirant
Pioneer AV Amplifier drop connection from Orbi RBR850
Greeting! I have a question about my Pioneer AV Amplifier (SCX-L89) keeps dropping connection. Recently I changed my Router from Apple Airport Extreme to Orbi RBR850 (with one Satellite). I connect...
- Mar 26, 2021
I would presume the AVR doesn't like the wired connection for some reason.
Ensure the AVR has updated FW/Software.
Keep the wireless connection.
ALEUNG
The firmware version is V3.2.16.22
I already tried reserve a ip address 192.168.1.46 to the AVR. But problem is still exists.
I need to unplug to power off the AVR. Then plug to power on again, the AVR can be found in the Orbi list. But dropped again after around 1 hour. I can say it's working perfectly in the old Apple Airport Extreme router.
Thanks
Mar 25, 2021Guru - Experienced User
IS the LAN cable of good quality? CAT6 is recommended.
Do other wired devices experience the same thing?
Try updating to v12 FW:
- ALEUNGMar 26, 2021Aspirant
I alreay got a brand new CAT6 cable and confirmed the firmware is most updated. Problem is still exists and this time dropped after 30 mins.
may be the only solution is to switch back to my old Apple Airport Extreme and sell out my Orbi........
