Johnatmh
Oct 04, 2020Tutor
Placement considerations - interference from other electronic devices?
I just ordered a 3 "node" ORBI RBK753 system and thinking about where to place the two satellites. Ideally I would like to place one in our family room directly behind our Samsung SmartTV and connec...
- Oct 05, 2020
Johnatmh wrote:I just ordered a 3 "node" ORBI RBK753 system and thinking about where to place the two satellites. Ideally I would like to place one in our family room directly behind our Samsung SmartTV and connect to the TV with a Wired connection. The second one I would like to place on a bookshelf within 2 feet of our Simplisafe Base Station. Is this a bad idea? Will placement near the Simplisafe Base Station create interference? Likewise will placing the other behind the TV cause interference or reduce the WIFI signal to other wireless devices?
Thank you in advance!
My personal 753 system is placed similar to what you are asking. Since this system is quite powerful, do not place the satellites too close to each other. Mine are a good 30+ feet apart.
Regarding my setup, the RBR750 is on the top shelf of my AV rack 1 foot from a wired receiver, wired Android Box, wireless Blueray, wired camera monitor, 2 feet from my wireless TV and Amazon Echo. The second one is upstairs and the third is downstairs in an adjacent building. I have no interference or other issues whatsoever. All 3 nodes of my 753 system give me extremely fast connections with great WIFI coverage and speed. WIFI6 speeds are great as well on supported devices.
You shouldn't have any interference issues with what you have suggested, providing your settings are correct and you choose WIFI channels with less traffic. 1,6 and 11 for 2.4Ghz are my choices as they are non overlapping. Regarding 5Ghz you can pretty much pick whatever you want. I'm on 48.
Mstrbig
Oct 05, 2020Master
