Eriksen76
Dec 25, 2023Apprentice
Please help can't reset ORBI 850 satelittes
Hi there. I am very frustrated sorry.. Today I factory reset my Orbi 850 router with the paper clip and I also wanted to reset the satelittes and pair them up again. It setup the router as it was fr...
- Dec 26, 2023
Ya not sure if the reset button is working. I do prefer using the ERASE button, which i've been told that also sends the FR command to ANY connected RBS and triggers there reset to beging there. I then recommend letting the RBR and RBS come to that semi ready state and allow the RBS to connect to the default SSID name and PW. Once the front LEDS are blue, then beging the setup wizard routine.
Is the 3rd RBS an RBS that you bought afterwards or an newer alien RBS? Reason for asking is that all RBS and RBR in a kit box have the same default SSID name and PW. Seems like the 3rd one is an alien RBS that you added later on. Which you can, just if and when you use the ERASE button and let the 3rd RBS do it's reset, it may not auto connect to the RBRs default SSID and PW. It will need to be re-synced using the Add Satellite function. Which I have done and tested out as I got a 3rd RBS this past summer and was worried it wouldn't connect. It did and worked when I had it online.
I would do this for RBS that are connected however not really reset, If there seen by the RBR, bring them near or in same room as the RBR. Trigger the ERASE function. Watch the 3rd RBS in back and the power LED should go from GREEN to AMBER Then back to GREEN, when you seen GREEN here, power OFF the 3rd RBS for now.
Watch the original RBS and leave them ON, the RBR and RBS should auto sync after the reset has been processed. Say 5-10 minutes. Once you see BLUE infront of the RBR, walk thru the setup wizard. Get the system setup with the two RBS.
WIll come back to the 3rd RBS later.
Dec 25, 2023Guru - Experienced User
Been told that if you factory reset the RBR using the ERASE button on the RBRs web page, this sends a FR command to any and all connected RBS, then all you need to do is after that processes, what for them to auto reconnect to the RBRs default SSID name, once there LED is BLUE In front, then begin the setup routine using the RBRs web page with a web browser or Orbi app.
How long did you press the reset button for? 15 second press in back of the RBR or RBS is needed, then release.
What FW version is loaded on the system?
Eriksen76
Your help is appriciated, thanks. Sorry for the long explanation below, but maby it helps.
Actually I believe that i did hold the clip for 15 seconds and maby longer. Tried for hours.
Its strange that I started resetting the router and it acted as if it had been factory reset. You know asking for which Internet connection i had. Afterwards it had the old SSID information etc. etc., But it still knew the name of the previously connected satellites (The were just shown as unavailable). So I would not call it a complete reset. Or maby it was actually reset and the satellites automaticly showed in the router webinterface because those were not reset? Could that be the case??
But I read that numerious people on the Internet wasn't able to reset satellites either. It should not be that complicated, i mean there is a reset button on the back of the satellites? It should be easy.
I'm running the latest FW on all 3 units: V7.2.6.21_5.0.20
In the meantime in desperation I rebooted my router a couple of times and suddenly the satellites reconnected to my router. But still with the old names ("Livingroom" etc. etc.) so I don't think that those had been reset.
I might try that type of FR you mention, but I am terrified if everything is going down again for hours.
My setup consist of a 852 set (You know a router and a satellite bought as a set) and then i bought another 850 satellite .
The the ones bought in a 2-set has the SSID default "ORBI79" and same default password for both router and satellite.
The third unit bought as a single one has SSID "ORBI73" and different default password than the set.
Not sure if that has influence on the method of factory resetting from the web interface? Will that still reset them all?
Please let me know what you think of above before I further.
Thanks
