Meow123
Jan 04, 2021Aspirant
Please Help! new AX6000 Orbi RBK853 disconnects intermittently, stops relaying packets. Can't game
I have the latest firmware, BUT Orbi disconnects games and kicks out of meetings. At intermittent intervals, Orbi will stop relaying the packets that are received. Packets will be sent out properly f...
- Jan 07, 2021
Thanks for your advice, FURRYe38. The Orbi Support Phone team suggested that I change the DNS address numbers to a more stable server. That fixed the problem immediately after reboot.
Since the DNS changes, I ran an endurance test, and now for more than 24 hours, there are no more disconnection drops or downtimes. The new Orbi is now running well.
Thanks!
Jan 05, 2021Guru - Experienced User
Meow123
Jan 07, 2021Aspirant
Thanks!
- FURRYe38Jan 07, 2021Guru - Experienced User
Good to hear. Yes DNS is important. ISP is usually preferred. However 2ndary DNS can be used as well.
Enjoy. :smileywink:
