bpitts69
Dec 13, 2021Aspirant
Please Help! Wifi speeds on Orbi Satellites Slow
Need advice on really slow wifi speeds on Orbi satellites. Already had internet provider out to confirm everything working correctly and speeds at router are above 900mb/s consistently. In parts of...
- Dec 21, 2021
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try turning off ALL RBS. Does the speed drop when only the RBR being on?
Try turning OFF 2 RBS. Does the speed drop?
bpitts69 wrote:
Thanks for your response. Answer to questions:
1.Firmware is V4.6.5.14
2.Multi-Level Home: Router placed centrally on first floor with 3 satellites, including one upstairs.
3.I changed 5GHZ from auto to 48 and 2.4GHZ to 1.
Update: Slow wifi speeds are less frequent. Now happening a couple of times/day. Max speeds decreases from above 500 to 35-40.
Anything else I can try?
Dec 13, 2021Guru - Experienced User
Is the home single or multi level home?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-data
What speeds do you see with a ethernet PC connected to the RBR?
Turn OFF The RBS and test with wireless devices connected to the RBR first off.
- bpitts69Dec 21, 2021Aspirant
- FURRYe38Dec 21, 2021Guru - Experienced User
- bpitts69Dec 23, 2021Aspirant
Awesome thank you I think it worked!
- claudiutDec 23, 2021Apprentice
Firmware 4.6.5.14 is garbage. Look around the form to see how many people have issues with this version. Issues with this firmware are very diverse: satellites disconnecting randomly throughout the day, slow speeds, 2.4Ghz AX causing massive stability issues, etc.
If you still can I would recommend returning the equipment and buy a different brand. I'm reading others have good results with Asus XT8.
If you can't return you are out of luck and the only thing to do while waiting for NG to fix the firmware is to try changing settings (you have to search the forum to see what others have tried) and see what works for you. It seems that everyone has different results for same settings, which speaks a ton about the quality of this firmware.
FURRYe38: since your Netgear colleagues are so busy fixing the firmware, why don't you summarize all the settings people should try and post them in a separate thread. At least that would be good use of your time instead of asking your broken record questions.
bpitts69 wrote:Thanks for your response. Answer to questions:
