bpitts69
Dec 13, 2021Aspirant
Please Help! Wifi speeds on Orbi Satellites Slow
Need advice on really slow wifi speeds on Orbi satellites. Already had internet provider out to confirm everything working correctly and speeds at router are above 900mb/s consistently. In parts of...
- Dec 21, 2021
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try turning off ALL RBS. Does the speed drop when only the RBR being on?
Try turning OFF 2 RBS. Does the speed drop?
bpitts69 wrote:
Thanks for your response. Answer to questions:
1.Firmware is V4.6.5.14
2.Multi-Level Home: Router placed centrally on first floor with 3 satellites, including one upstairs.
3.I changed 5GHZ from auto to 48 and 2.4GHZ to 1.
Update: Slow wifi speeds are less frequent. Now happening a couple of times/day. Max speeds decreases from above 500 to 35-40.
Anything else I can try?
bpitts69
Dec 21, 2021Aspirant
Dec 21, 2021Guru - Experienced User
- bpitts69Dec 23, 2021Aspirant
Awesome thank you I think it worked!
- FURRYe38Dec 23, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- FURRYe38Dec 24, 2021Guru - Experienced User
- bpitts69Dec 24, 2021Aspirant
Yes still working!
- SureFootDec 24, 2021Aspirant
deleted--question answered
