TURBOGUARD
Jun 07, 2020Tutor
Plex stopped working, new orbi FW and more...
I have the RBK852 1. Last week plex stopped working outside my own network. Did they push another update Recently I didn’t know about? I can’t seem to figure out how to fix this. 2. When trying...
Chuck_M
Jun 07, 2020Mentor
Are you on a VPN?
Do you have port forwarding to your Plex Server?
Is Plex (server) running on your PC or another device on your local network?
- Retired_MemberJun 09, 2020
Plex is working great for me. Make sure the computer your Plex server is installed on has an assigned static IP address. Go into your Plex settings and set port to manual and tick the box so port 32400 is being used. Click 'Save.' Go into your Orbi router and turn on port forwarding to the static IP you assigned and use the same port number, 32400.
