TURBOGUARD
Jun 07, 2020Tutor
Plex stopped working, new orbi FW and more...
I have the RBK852 1. Last week plex stopped working outside my own network. Did they push another update Recently I didn’t know about? I can’t seem to figure out how to fix this. 2. When trying...
Robertgold123
Jun 14, 2020Tutor
I just saw your post and you may have already resolved your issues, but I had a similar issue with Plex. It turned out that somehow my Plex settings disabled the "Allow Fallback to Insecure Connections" option. As soon as I re-enabled it, everything worked perfectly.
I have not experienced problems accessing Orbilogin, but I had problems with the the Advanced Page not displaying correctly with Chrome until I changed the Site Setting (which you can access by clicking on the "lock" icon in the address bar) by enabling flash and allowing insecure content. Apparently the Orbilogin page has "mixed content" which Chrome now blocks by default. I hope this is helpful.
TURBOGUARD wrote:
I have the RBK852
2. When trying to access Orbilogin it always sends me to the reset password link. I reset it. And then re-login and bam back to password reset. It’s done this like 5 times now.
3. I’m on FW 3.2.11.2_1.2.13, I see that 3.2.15.25 is out, anyone having any issues or should I update and hopefully the two previous comments will be solved?
can't help you with your log-in issues,
