Télépermanence
Oct 04, 2022Aspirant
Plusieurs comptes Orbi - Multiple Orbi Accounts
Hello, I discovered Orbi and I find it super efficient, as I have a business, I would like to be able to offer Orbi to my customers. Can you please tell me if I can have multiple sites saved in the...
CrimpOn
Oct 04, 2022Guru - Experienced User
Yes, the Orbi 'app' can administer multiple Orbi systems. Select the menu option "Set up a New Orbi System".
Please explain more about "change the name" of the system.
Under "Router Settings" there is an option to change the descriptive name of the router. Is this what you want to do?
Télépermanence
Great thanks a lot !
On the screenshot below, here is the name that I put circled in green but it does not appear on the main page.
As I can only put one image, I make a second post with just the 2nd image.
Thanks a lot
- TélépermanenceOct 04, 2022Aspirant
- CrimpOnOct 05, 2022Guru - Experienced User
You are correct. This is a flaw in the Orbi 'app'.
However, the name should appear correctly on the Network Map.
Administering multiple WiFi systems is a complicated business. I am not certain that the residential Orbi and Orbi 'app' are well suited for this application. There are all sorts of questions:
- Are the users of these system to be allowed to have management access to them?
If all these systems are tied to one Orbi 'app', then the same credentials must be used to access any of them.
A system cannot be tied to two different credentials. - Will any of these systems need configurations that cannot be done with the 'app'?
Such things as Port Forwarding, DNS server changes, etc.
The app does not provide access to those features. - Will any of them require use of Parental Controls?
This is WAY beyond my competence.
