Télépermanence
Oct 04, 2022Aspirant
Plusieurs comptes Orbi - Multiple Orbi Accounts
Hello, I discovered Orbi and I find it super efficient, as I have a business, I would like to be able to offer Orbi to my customers. Can you please tell me if I can have multiple sites saved in the...
Télépermanence
CrimpOn
Oct 05, 2022Guru - Experienced User
You are correct. This is a flaw in the Orbi 'app'.
However, the name should appear correctly on the Network Map.
Administering multiple WiFi systems is a complicated business. I am not certain that the residential Orbi and Orbi 'app' are well suited for this application. There are all sorts of questions:
- Are the users of these system to be allowed to have management access to them?
If all these systems are tied to one Orbi 'app', then the same credentials must be used to access any of them.
A system cannot be tied to two different credentials. - Will any of these systems need configurations that cannot be done with the 'app'?
Such things as Port Forwarding, DNS server changes, etc.
The app does not provide access to those features. - Will any of them require use of Parental Controls?
This is WAY beyond my competence.
