wifiblues
Aug 23, 2021Luminary
poor backhaul on RBS750
hi all - why doesn't the RBK752 show up under Models - that is screwy! why do you think the RBS750 is showing poor backhaul? The firmware is up to date v4. here is the situation as best as i can...
Aug 23, 2021Guru - Experienced User
80 ft is quite a bit of distance. They need at least 30 ft between them to roam properly but 80 ft might be to much.
You can try moving them around a little before adding more satellites.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
- wifibluesAug 23, 2021Luminary
thank you. i will certainly experiment and move the satellite closer to the router.
