Snornado
Sep 19, 2020Aspirant
Poor support
I am extremely dissatisfied with the recent support received (or not received) re: my Orbi router. I purchased a ProSupport package but cannot find a phone number of method of contacting the "suppos...
Snornado
I was able to resolve myself, no thanks to support.
Thank you for the offer to assist.
My problem was caused by changing the channel on my 2.4GHz.
i made the change and hit apply. i could not connect to the primary WiFi after that - invalid password - password was not change.
could connect to the guest WiFi.
FURRYe38 wrote:What product are you referring too.
Not much we can do to help you with phone support experiences here in the forums.
You can contact a forum moderator to help you with that.
If you have a problems with technical problems, you can post about and see if forum users can help you out as much as they can.
Good Luck.
Sep 19, 2020Guru - Experienced User
What product are you referencing?
