phreekeguy
Mar 08, 2020Aspirant
Poor WiFi download Speed RBR852
Ok so hopefully you guys and gals can help me. Just bought the Orbi RBR852 WiFi6 latest Firmware, I have 500 down and 500 up fios thru Frontier. My Speed going into the Orbi Is great 512/560 wired co...
KMDonlon
Mar 08, 2020Virtuoso
Perhaps QOS is to blame. I have fiber gig, 1000 up & down and get 650+ up and down on my phone... 800+ on my laptop with my Intel AX201 WiFi card. From 20 plus feet away.
I do not us the speed test as I have read not to use it with gig. Perhaps a factory reset and do not enable QOS.
- phreekeguyMar 08, 2020Aspirant
Thank you for the reply. When i got into the orbi advanced interface there is no way to disable QOS all that is there is a speedtest. Maybe a bad firmware upgrade?
- KMDonlonMar 08, 2020VirtuosoNo way to disable other than a factory reset and do not run a speed test in the web gui or Orbi app.
Ok did that. No speed test. No difference. Also turned off WMM for 2.4 and 5 Ghz off and no difference. Turned off all other wifi devices except my laptop and desktop and no difference. Im stumped.
