phreekeguy
Mar 08, 2020Aspirant
Poor WiFi download Speed RBR852
Ok so hopefully you guys and gals can help me. Just bought the Orbi RBR852 WiFi6 latest Firmware, I have 500 down and 500 up fios thru Frontier. My Speed going into the Orbi Is great 512/560 wired co...
phreekeguy
Thank you for the reply. When i got into the orbi advanced interface there is no way to disable QOS all that is there is a speedtest. Maybe a bad firmware upgrade?
KMDonlon
Mar 08, 2020Virtuoso
No way to disable other than a factory reset and do not run a speed test in the web gui or Orbi app.
- phreekeguyMar 08, 2020Aspirant
Ok did that. No speed test. No difference. Also turned off WMM for 2.4 and 5 Ghz off and no difference. Turned off all other wifi devices except my laptop and desktop and no difference. Im stumped.
- KMDonlonMar 08, 2020VirtuosoStrange indeed, have you tried different WiFi channels?
Hopefully someone else will have other thoughts on the subject. - FURRYe38Mar 09, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?WMM needs to be enabled always. Under Advanced Tab/Advanced Settings/Wireless Settings
Disable IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Use WiFi Sweet Spots on your phone to see what the connection rate is between the phone and RBR. Leave the RBS off for now.
phreekeguy wrote:Ok did that. No speed test. No difference. Also turned off WMM for 2.4 and 5 Ghz off and no difference. Turned off all other wifi devices except my laptop and desktop and no difference. Im stumped.
- phreekeguyMar 09, 2020Aspirant
Thanks for the reply. Firmware 3.2.10.11_1.2.12. Modem FIOS-G1100. Home Size 2100 SQ FT. Distance is 28 ft.. 2.4 Is on Channel 11 now. Not sure on Neighbors i know of one guy next door. WMM is on. IPv6 is disabled. All i can do with the 40 MHz is disable the 20/40Mhz Coexistence. Dont see a way to Change it to 40MHz. So that Firmare is new and i did not choose to update to it but now all i get is random disconnects and i dont see the Firmware on their wbsite. Thats Kind of odd. No changes in download speed. The RBR 852 Should be more that enough for my house size. Dont think that is the problem.
