phreekeguy
Mar 08, 2020Aspirant
Poor WiFi download Speed RBR852
Ok so hopefully you guys and gals can help me. Just bought the Orbi RBR852 WiFi6 latest Firmware, I have 500 down and 500 up fios thru Frontier. My Speed going into the Orbi Is great 512/560 wired co...
phreekeguy
Mar 09, 2020Aspirant
Why is it still trying to force that firmware on me. Says i have an update. Dont want to do it though.
phreekeguy
Yes it says connection mode for FIOS Modem is bridge.
- FURRYe38Mar 09, 2020Guru - Experienced User
Ok, thanks for letting us know, just making sure.
Try a reset and setup from scratch. I would power OFF the FIOS modem for 30 seconds then back on as well when you reset the RBR.
Can always go back to what was working. Just know that you don't have to apply what the RBR finds for FW updates.
- phreekeguyMar 09, 2020Aspirant
Ok will do thanks again. Just was wondering why its trying to update to new firmware if its not and release version, not on their website?
Well, we've asked NG to post soem beta FW in the beta forum for Orbi AX. It was made available via the update servers. Possible NG is making it availalble to the public by accident. Not sure. They usually don't make anything available until it goes to release officially.
Ahhh ok, well thanks again for all the help. Have a good day.
Enjoy. :smileywink:
