Paul50
Jun 22, 2021Aspirant
Port Forwarding Not Working
I have been having trouble with my Plex server not being accessable remotely. One the troubleshoot tips was to assign a static IP to the NAS and assign port 32000. I have done both of those and it ha...
Jun 22, 2021Guru - Experienced User
Is the IP address you set a static one set ON the NAS thats outside of the RBRs DHCP IP address pool or is it a reserved IP address set ON the RBR with in the RBRs DCHP IP address pool?
When checking port status, upnp should be disabled, Port Forwarding rule should be configured and the port has be to actively being used before checking the state or you'll get a false negative if it's not actually being used.
- Paul50Jun 22, 2021Aspirant
Hardware Version: RBR750
Firmware Version: V3.2.18.1_1.4.14
Modem: Calix
Model: 716GE-I
The ISP uses DHCP and I have reserved an IP on the LAN for my NAS.
I had UPnP disabled, but I am not sure how to get the port to be actively used as Plex says it cannot establish a connection.
- FURRYe38Jun 22, 2021Guru - Experienced User
You've probably already looked at this guide?
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
