virsaint
Dec 31, 2020Aspirant
Port Forwarding Problem
I just changed my ISP from Cox (cable internet) to Gonetspeed (FTTH). I have security cameras that I used to be able to access from anywhere when I had Cox cable. I subscribe to a DDNS service. I set...
Dec 31, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? IF so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
virsaint
Thank you for your response and your suggestions. Replying to your questions:
Firmware Version: V3.2.16.22_1.4.9
ONT is labeled Nokia but found a brochure for same model G-010G-A but brochure is from Alcatel Lucent.
I will look into your suggested next steps and reach out to my ISP since I don't have access to the ONT config. If they could bridge the modem, everything else would be within my capabilities. Beyond that, I would be treading very carefully.
Thank you so much for giving me some directions.
Happy New Year!
Vir
- FURRYe38Dec 31, 2020Guru - Experienced User
Ok, have the ISP check for NAT at the ONT or anything in between the ONT and the Orbi RBR. Default IP address string for NG is 192.168.1.1 and if your seeing 10.someting on the WAN or LAN side of the Orbi router, this means something up stream from the Orbi is using 192.168.1.1 and Orbi is changing to avoid a conflict.
- virsaintDec 31, 2020Aspirant
Noted ... thanks, again!
Is it OK with you if I forward our exchange to my ISP?
Not sure thats needed. Something to ask the ISP about. If your in a signal NAT condition, you should need much if any PF configurations. Only use that where needed would be best recommendation.
