onarock
Sep 15, 2020Tutor
Port Forwarding rules not saving
I currently have an Orbi RBR750 (firmware V3.2.16.6_1.4.4) and anytime I try to add a custom port forwarding rule it does not work. When I hit the add custom service button I am taken to the Ports...
Sep 15, 2020Guru - Experienced User
What browser are you using?
What input values are you using?
onarock
Sep 15, 2020Tutor
I am using Chrome Version 85.0.4183.102 (Official Build) (64-bit)
I am trying to forward port 32400 (both external and internal) to internal ip address 10.0.0.62. TCP protocol
- onarockSep 15, 2020Tutor
FURRYe38 hey your response made me think to try another browser (ive not had to do that in so long it never dawned on me).
For some reason port forwarding rules are not saving in chrome, but when I tried in microsoft edge it worked no problem.
thanks for responding so quickly.- FURRYe38Sep 15, 2020Guru - Experienced User
Ok, I'm using Opera.
Not a fan of chrome for any router operations.
Glad you found it working with a different browser.
Mark your thread as solved so others will know.
Enjoy.
Like this?
