onlize
Aug 16, 2022Aspirant
Port forwarding stopped working on RBR750
Hello, I have an Orbi RBR750 with the latest firmware V4.6.5.14_2.0.54. Hi, I have a problem with port forwarding. It used to work but stopped working. I did not change anything, and I am not sur...
- Aug 16, 2022
Glad you figured it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Good Luck. 📡
CrimpOn
Aug 16, 2022Guru - Experienced User
Port forwarding typically relies on two concepts:
- Dynamic DNS. Because most customers are assigned IP addresses that may be changed by the ISP (without notice) at any time, it is customary to use a DDNS service to set up an internet name that will automatically update to the new IP address. Orbi supports only a couple of DDNS services (noip.com, dyn.com). If somehow the DDNS service is no longer correct, then they will not map correctly.
- Hosts being open to accept connections.
How about double-checking:
- That the ports are open to the internet by using one of the common testing web sites, such as https://www.grc.com/shieldsup
- Also verify that the public IP address reported by the web test matches what the IP address that is current in the DDNS service.
- onlizeAug 16, 2022Aspirant
Hello, thank you for your reply.
Ports are opened and listening. I can telnet to both servers internally, but I cannot connect when I am outside of my network.
I tried to connect using the ddns service and the public IP address that I see in my Orbi control panel. I have the same results. No connections.
