onlize
Aug 16, 2022Aspirant
Port forwarding stopped working on RBR750
Hello, I have an Orbi RBR750 with the latest firmware V4.6.5.14_2.0.54. Hi, I have a problem with port forwarding. It used to work but stopped working. I did not change anything, and I am not sur...
- Aug 16, 2022
Glad you figured it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Good Luck. 📡
onlize
Hello, thank you for your reply.
Ports are opened and listening. I can telnet to both servers internally, but I cannot connect when I am outside of my network.
I tried to connect using the ddns service and the public IP address that I see in my Orbi control panel. I have the same results. No connections.
CrimpOn
Aug 16, 2022Guru - Experienced User
Open and listening is reported by a web site?
- onlizeAug 16, 2022Aspirant
Yes, I used it for years, with a previous router and Orbi. It stopped working during the last couple of months. I do not use it outside too often, so I am unsure when it stopped.
- FURRYe38Aug 16, 2022Guru - Experienced User
Any new changes on the Orbi system in last couple of months? When was FW last updated?
If nothing was changes on the Orbi system, possible a ISP issue.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- onlizeAug 16, 2022Aspirant
Thank you for your reply.
I use NETGEAR Cable Modem CM1000.
I did not change anything major on my router for some time now. Maybe I added a couple of IP reservations for some of my new devices.
I followed your advice to unplug the modem and router and started as you recommended, but it did not help.
