onlize
Aug 16, 2022Aspirant
Port forwarding stopped working on RBR750
Hello, I have an Orbi RBR750 with the latest firmware V4.6.5.14_2.0.54. Hi, I have a problem with port forwarding. It used to work but stopped working. I did not change anything, and I am not sur...
- Aug 16, 2022
Glad you figured it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Good Luck. 📡
CrimpOn
Aug 16, 2022Guru - Experienced User
This is hard to get my head around:
- The two servers are on the Orbi Attached Devices page with the desired LAN IP addresses (that the ports are forwarded to).
- The two servers will accept a telnet connection from the LAN.
- The Orbi shows two ports being forwarded from the internet to specific ports on those two servers.
- The two servers accept connections on those ports from the LAN.
- Shield's Up! shows that those two ports are open to the internet.
- Yet, when a device outside the LAN attempts to connect to the public IP on one of those ports, "nothing happens".
Would you mind sharing which ports are being forwarded and what type of server they are (generically: Windows, Linux??... HTTP, HTTPS, FTP, media, telnet??)
How is the situation being tested? (When I set up port forwarding, I typically drop the WiFi connection on my phone, start the phone's WiFi Hot Spot feature, connect a laptop to the phone, and perform tests.)
onlize
Thank you for all your help. It was my mistake. It looks like location where I am now block ports that I am trying to use. When I tested it with my phone without any Wi-Fi, everything works.
Thank you everyone for all your help!
- FURRYe38Aug 16, 2022Guru - Experienced User
Good Luck. 📡
