onlize
Aug 16, 2022Aspirant
Port forwarding stopped working on RBR750
Hello, I have an Orbi RBR750 with the latest firmware V4.6.5.14_2.0.54. Hi, I have a problem with port forwarding. It used to work but stopped working. I did not change anything, and I am not sur...
- Aug 16, 2022
Glad you figured it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Good Luck. 📡
onlize
Thank you for all your help. It was my mistake. It looks like location where I am now block ports that I am trying to use. When I tested it with my phone without any Wi-Fi, everything works.
Thank you everyone for all your help!
Aug 16, 2022Guru - Experienced User
Good Luck. 📡
