AE8U
Dec 16, 2022Aspirant
Port forwarding stopped working
Port forwarding on my Orbi RBR750 has stopped working - not certain when, but in the last 2-3 weeks. Here is the situation. I have port forwarding set up to forward port 8443 to IP 192.168.201. I...
- Dec 19, 2022
Ya reboots and power cycles are two different things.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Dec 19, 2022Guru - Experienced User
Any progress on this?
AE8U
Dec 19, 2022Aspirant
This has been solved. A Netgear tech had me update to the latest firmware and then power off, wait 30 seconds and power on. (Not sure but I think this second step may have been the solution, since it had been working with the previous firmware.)
As a side note, I thought that a software reboot and a power off and on accomplished the same thing, but it seems like that is not the case.
- FURRYe38Dec 19, 2022Guru - Experienced User
Enjoy. 📡
