chrispib's avatar
chrispib
Port forwarding
I have port forwarding set from external IP:port Y to internal IP:port X. However in my Netgear logfile I see that independent of port Y, the whole range of external ports are forwarded to internal IP-B:port X.
In my opinion if it is not port Y it should be blocked and not get forwarded at all. Am I right or did I overlook something?
  • FURRYe38's avatar
    There a NG model or product model your referring too?
    • chrispib's avatar
      chrispib
      Orbi AX4200 WiFi 6 High-Performance Router(RBR750)
  • CrimpOn's avatar
    CrimpOn
    Would be helpful to see a screen capture of the port forwarding rule and some of those log entries.
    (There should not be anything private or sensitive about posting this information.)
