matthew-s
Mar 15, 2020Aspirant
Portion of devices can connect to ORBI AX6000 / RBK852 WiFi network, but not access internet?
Yesterday I set up an AX6000 / RBK 852 network. I have many devices attached to the network w/o issue (3 iphones, 2 Lenovo laptops, Google home mini, a few devices on the wired network). Two ...
- Mar 15, 2020
Ok - solved - looking at a sidebar suggestion on a similar thread.
We have a Circle appliance. Hard wired. I had to go into the Circle app, select "Setting" and turn "Router Compatability Mode" on.
There are other devices managed by Circle that did work w/o this change, so it was baffling, but now things work, so there you go.
Mar 15, 2020Guru - Experienced User
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
What OSX version is loaded on the mac book pro? I have a 2019 MBP 15" OSX 10.14 and 10.15 dual boot and it connects fine. If you disabled security on the two devices, and they still won't connect, possible problem with the wifi drivers on these devices.
