matthew-s
Mar 15, 2020Aspirant
Portion of devices can connect to ORBI AX6000 / RBK852 WiFi network, but not access internet?
Yesterday I set up an AX6000 / RBK 852 network. I have many devices attached to the network w/o issue (3 iphones, 2 Lenovo laptops, Google home mini, a few devices on the wired network). Two ...
- Mar 15, 2020
Ok - solved - looking at a sidebar suggestion on a similar thread.
We have a Circle appliance. Hard wired. I had to go into the Circle app, select "Setting" and turn "Router Compatability Mode" on.
There are other devices managed by Circle that did work w/o this change, so it was baffling, but now things work, so there you go.
matthew-s
- FURRYe38Mar 15, 2020Guru - Experienced User
AH ok. That would be a cause. Glad you go it working.
Enjoy. :smileywink:
