tnine
Feb 08, 2022Aspirant
Possible bricked Satellites after downgrading from v4.6.7.5 to v 4.6.3.16
Hello, Since upgrading to the experimental firmware here, I've had a lot of issues with high latency and packet loss on my WAN (ping times jump to over 17 seconds for the next hop for 1-2 seconds ...
KMDonlon
Feb 08, 2022Virtuoso
I was able to get my satellite up and running multiple times after playing around with the different firmware versions following these instructions:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
- NGSvenskFeb 08, 2022Apprentice
I have the same thing happening with a downgrade! I cannot do a factory reset on my satalite. Is it same procedure with the TFTP program RBS? Which port is port 1? Because it looks like I cannot factory reset my RBS, the ip address is .42 instead of .1 but I tired both. What firmware were you able to bring it back up with?
- KMDonlonFeb 09, 2022VirtuosoI used v. 4.6.3.16... saved a copy for the RBS on my laptop, plugged it in via an Ethernet cable to my laptop only, not the RBR and was able to get satellite to come back (blue ring after pulsing white) following the instructions to the letter. Did it 5 or so times without issue.
- tnineFeb 09, 2022Aspirant
Hi KMDonlon ! What program and programming device did you use? I'm trying to use nmrplfash, but it appears there's a bug when interacting with OSX 12.2.
https://github.com/jclehner/nmrpflash/issues/92
If that's what you used successfully, I'll boot into my Windows Boot camp and give it a shot from there.
