tnine
Feb 08, 2022Aspirant
Possible bricked Satellites after downgrading from v4.6.7.5 to v 4.6.3.16
Hello, Since upgrading to the experimental firmware here, I've had a lot of issues with high latency and packet loss on my WAN (ping times jump to over 17 seconds for the next hop for 1-2 seconds ...
Feb 10, 2022Guru - Experienced User
I recommennd you contact NG support and ask about RMA options.
marshall2553 wrote:
I have the exact same problem and posted about it here . I've tried pretty much everything and all of my satellites still have the flashing white status light and appear to be in a reboot loop. I attempted to downgrade via nmrpflash and although it appeared to be successful based on the console output there was no change once I rebooted the satellite. I guess I should try to get an RMA started at this point. I've moved on to a Ubiquiti setup, but it would be nice if I could get these working and sell or gift them to someone. When they work they're great, but the bugs and connectivity issues have been frustrating.
marshall2553
Feb 10, 2022Aspirant
FURRYe38 wrote:I recommennd you contact NG support and ask about RMA options.
marshall2553 wrote:I have the exact same problem and posted about it here . I've tried pretty much everything and all of my satellites still have the flashing white status light and appear to be in a reboot loop. I attempted to downgrade via nmrpflash and although it appeared to be successful based on the console output there was no change once I rebooted the satellite. I guess I should try to get an RMA started at this point. I've moved on to a Ubiquiti setup, but it would be nice if I could get these working and sell or gift them to someone. When they work they're great, but the bugs and connectivity issues have been frustrating.
How do I go about doing that? I purchased them in August of last year. When I view my NG account the support options for my RBR853 are basically post here, purchase new hardware or purchase a support contract. I tried the first option and the other two are not happening. If I go to the "Contact Us" page and try to open a support case I only get knowledgebase suggestions and a link to purchase a support contract. The phone support options say "Create a case before calling". My free tech support ran out in November, though it does show that they're covered by the hardware warranty until August 2022.
- KMDonlonFeb 10, 2022VirtuosoThe links I posted do work, from what I have read nmrpflash doesn't seem to work, using windows and TFTP worked for me multiple times... I hope you try this and have success.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client- marshall2553Feb 10, 2022Aspirant
Thanks. I tried TFTP but got a "Connect request failed" error each time. Maybe it was a timing thing, the satellite reboots fairly quickly and I could see the connection dropping sporadically on my PC. When you say it worked for you, was that after downgrading from 4.6.7.5 to 4.6.3.16?
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client- KMDonlonFeb 10, 2022VirtuosoYes, I downgraded several times from both versions... did you follow the sequence exactly and use the external program listed?
I wish I could help more on this since I had no problem restoring, I really hope you get your satellite back up and running 👍
- FURRYe38Feb 10, 2022Guru - Experienced User
Please reach out to a forum moderator to see what options you may have:
