Itos
Feb 21, 2020Follower
Possible connection between the two satelites of Orbi RBK853?
Do the satelites connect with each other or does the connection need to go from the main router to the individual satelites? I am asking this becase I only have the option to connect the router on on...
Feb 21, 2020Guru - Experienced User
In a Daisy Chain they should work well. Mine work well however are not in a daisy chain in my 5000sq ft home. The farthest RBS should connect to the next closer RBS thats near the RBR.
I would contact NG support to see if they are officially supported in the EU.
