Itos
Feb 21, 2020Follower
Possible connection between the two satelites of Orbi RBK853?
Do the satelites connect with each other or does the connection need to go from the main router to the individual satelites? I am asking this becase I only have the option to connect the router on on...
Bandito
Feb 21, 2020Luminary
The EU uses some different channels than we do here in the US, so you may run into some issues there.
You'll have to check the Input voltage requirements on your AC adapters to see if they are universal or not. The ones that came with my Orbi RBK852 are US only, much to my surprise, though this is not an issue for me.
Good luck!
