weirdbeardmt
Oct 09, 2024Guide
Possible to backaul wirelessly but disable radio?
RBR750 with 2x RBS750, AP Mode Is it possible to disable the radio/transmit on a node by node basis but still have wireless backhaul? I need to get a (wired) POE device to my network in a loc...
- Oct 09, 2024
That's mostly covered in my other topic: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/RBR750-unstable-satellites-keep-disconnecting/td-p/2383790. But in short, I had one router and 3 satellites and the satellites were really unstable which through trial and error I attributed to over-provisioning because having removed one of them thing have settled down.
In terms of the device, I can use a power injector for the 'P' part, but I still need network access for the 'E' part... so an Ethernet port on *something* - I was hoping I could use the (now) spare RDS for it but without re-introducing it as a mesh node.
It transpires that 'wireless bridge mode' is the tech required to achieve this... and the RBS750 seemingly doesn't support it.
Netgear (and assorted other manufacturers) do have devices for this specific purpose.
Oct 09, 2024Guru - Experienced User
Why do you think that would "over provision" your network?
My network has to much coverage in that I should probably disable one of my satellites based on size, but it works fine.
I'm a little curious how you're planning on doing this. Satellites---->to POE device?
A little more details about your setup (like distance/coverage/different building?) etc might help us to give you better options.
weirdbeardmt
Oct 09, 2024Guide
