weirdbeardmt
Oct 09, 2024Guide
Possible to backaul wirelessly but disable radio?
RBR750 with 2x RBS750, AP Mode Is it possible to disable the radio/transmit on a node by node basis but still have wireless backhaul? I need to get a (wired) POE device to my network in a loc...
- Oct 09, 2024
That's mostly covered in my other topic: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/RBR750-unstable-satellites-keep-disconnecting/td-p/2383790. But in short, I had one router and 3 satellites and the satellites were really unstable which through trial and error I attributed to over-provisioning because having removed one of them thing have settled down.
In terms of the device, I can use a power injector for the 'P' part, but I still need network access for the 'E' part... so an Ethernet port on *something* - I was hoping I could use the (now) spare RDS for it but without re-introducing it as a mesh node.
It transpires that 'wireless bridge mode' is the tech required to achieve this... and the RBS750 seemingly doesn't support it.
Netgear (and assorted other manufacturers) do have devices for this specific purpose.
weirdbeardmt
Oct 09, 2024Guide
Oct 09, 2024Guru - Experienced User
A simple wireless extender would work as well. You'd just disable the ssid on it.
It still needs the wireless enabled for the backhaul but you could set that up yourself.
Got any of those sitting around?
Or you could go MoCa adapters or powerline adapters to get ethernet to where you're trying to.
