bobbinman
Jun 22, 2021Aspirant
pre sales advice Orbi RBK 753
Hi I am thinking of upgrading my wifi ro WIFI 6. I was looking at the Orbi RBK753 I live in the UK. My ISP is Plusnet and I am on FTTC connection. My current router/modem/wifi is a Billion BiPAK8800A...
Jun 22, 2021Guru - Experienced User
For modmes with built in routers...This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
