bobbinman
Jun 22, 2021Aspirant
pre sales advice Orbi RBK 753
Hi I am thinking of upgrading my wifi ro WIFI 6. I was looking at the Orbi RBK753 I live in the UK. My ISP is Plusnet and I am on FTTC connection. My current router/modem/wifi is a Billion BiPAK8800A...
Jun 22, 2021Guru - Experienced User
For modmes with built in routers...This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
bobbinman
Thanks for the reply, silly question time. Can I just plug in the orbi RBK753 router straight into my socket and configuer it with my isp details? there fore not haveing the oild billion router on the system at all?
Thanks again for your time.
- FURRYe38Jun 22, 2021Guru - Experienced User
Possible however thats something to ask your ISP about to see what there requirements are. If thats something they support then the RBR should work in it's place. Contact the ISP first and get this information.
- bobbinmanJun 22, 2021Aspirant
They did say that as long the router was Fiber enabled, FTTP or FTTC then it should be ok. Cant find this info on the netgear site though. Thanks Chris
Ya, thats not something Orbi systems support. So you'll need to use there Modem/ONT as the interface to there services and connect the RBR to the modem/ONT. RBK systems don't have built in modems/ONT. Only the CBR40 and CBR750 have built in cable modems and these work only on cable ISPs, not Fiber/FTTC.
