gogoy7
Jul 14, 2023Follower
Pretty sure my Orbi dropped connection again
I was streaming a channel on my DirecTV Satellite and noticed that the channel went back to live TV this disconnecting from the streaming g channel. Also noticed my Amazon Echo seemed to disconnect t...
Jul 14, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
