Atlantis6694
Jul 09, 2022Aspirant
Primary wireless not working
I've been having this same issue. Persisting through several firmware versions, since I purchased the devices in April. I had to call support at one point and was on the phone for hours as we factory...
Jul 09, 2022Guru - Experienced User
Is the RBS directly connected to the back of the RBR or is there a patch panel and or LAN switch in between them?
What CAT# LAN cable are you using? CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
