Atlantis6694
Jul 09, 2022Aspirant
Primary wireless not working
I've been having this same issue. Persisting through several firmware versions, since I purchased the devices in April. I had to call support at one point and was on the phone for hours as we factory...
Atlantis6694
Not sure why this got moved to its own thread. I was more trying to help others that came across the last one like I did.
I assume the line of questions are a generic discovery to help pinpoint issues, not issue specific.
What is the size of your home? Sq Ft? 1400 sqft1
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. about 20ft minimal interference in between. When DHCP is working, backhaul always shows solid. Currently have it wired though, but have moved it from right next to the RBR to different spots in different rooms. Issues persist.
Is the RBS directly connected to the back of the RBR or is there a patch panel and or LAN switch in between them? Directly
What CAT# LAN cable are you using? CAT6 is recommended. CAT5E or CAT6
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz. Radio band isn't too saturated that Auto does its job at finding less congested bands. Use site survey tool to check.
hiltxan
I saw a reply to the other thread and also that your post got moved to a new one.
I did suspect that there was an issue with the orbi router DHCP server for wireless for the primary wifi, since the guest and wired clients always worked.
I tried to use a spare dd-wrt router and use that as a DHCP server, disabling the orbi router DHCP services. The modem was still connected to the orbi WAN port. The orbi router cannot connect to the orbi satellites (both wired and wireless) so I lose the mesh function when I do this and I think it's because the orbi router is not able to commnuicate/assign IP addresses to the satellites. I tried to power cycle and reset the satellites but none of this worked.
Is it possible to use a spare router for DHCP server and still be able to use the satellites? How do I configure this?
- Atlantis6694Jul 10, 2022Aspirant
I'm seeing the same behavior and suspected that's why the satellites keep going out of sync as well.
I can't imagine turning off DHCP on the orbi would (by design) disable mesh functionality. At least I hope not.
My next steps are going to be:
1. Setup Windows Server virtual machine and configure a DHCP scope
2. Turn off Orbi DHCP
3. See what happens.
Is there a way to see the current DHCP table on the Orbi? Clients, leases and all that? Also, is there a way to dump all reservations, clear it out, short of reconfiguring DHCP? Besides the "attached devices" which I can't imagine is everything that has a lease.
Reason I ask is, IF there is no issue with the Orbi DHCP service itself, I have a hunch on what's happening but I need to see that table to be sure.
hiltxan any chance you have any apple devices on your network as well? iPad, iPhone, Mac? I have a few, and wondering if the "Limit IP Tracking" feature (which masks and changes the devices network MAC address) is confusing the orbi DHCP and essentially using up all the available DHCP leases because it thinks they are separate devices each time it changes. No confirmation on this, just a hunch if it turns out that DHCP is working fine on the Orbi- hiltxanJul 12, 2022Aspirant
I have noticed that when the router dies, only 20-30% of the devices are able to connect. It's usually the windows laptops and some TVs that are still able to connect to primary wifi. Most apple devices and other smart home devices (switches, lights, thermostats) are all unable to connect, which makes me think it has to be a netgear ORBI issue rather than device specific or even just related to apple devices.
So far I enabled email logging on someone's suggestion and it has remained stable so far, but I haven't had any power outages or things that can trigger it so I'm just waiting until the next episode.
- Atlantis6694Jul 12, 2022Aspirant
Interesting. So the mail logging is acting as some soft of keep alive for the DHCP listener/service on your end it looks like.
I did end up building a server VM and installing DHCP there. Turned off DHCP service on my router, and it’s been golden since. Not a single issue. So i don’t believe it was the private wifi address feature causing it from my apple devices either, and this confirms it.I’ve rebooted my router several times since then as well, and stability has been consistent.
