ahswp
Oct 27, 2021Apprentice
Printer connection issue
I have an Epson ET-5800 connected to wifi. Almost every day it disconnects from my wifi (Orbi 750 mesh). When I unplug it, then plug it back in, it reconnects. Its really frustrating. When I've cont...
Mikey94025
Oct 27, 2021Hero
I've found that you can often maximize Orbi AX compatibility with older wireless devices with:
- In http://orbilogin.com, Advanced tab, Advanced... Wireless Settings set CTS/RTS Threshold for both bands to 2347
- If that doesn't work, in Setup... Wireless Setup also try unchecking "Enable 2.4G" for Enable AX to disable AX for the 2.4Ghz band (only). You're AX devices, if any, are probably using 5Ghz anyway so disabling AX for 2.4Ghz doesn't really hurt you.
