ahswp
Oct 27, 2021Apprentice
Printer connection issue
I have an Epson ET-5800 connected to wifi. Almost every day it disconnects from my wifi (Orbi 750 mesh). When I unplug it, then plug it back in, it reconnects. Its really frustrating. When I've cont...
Oct 27, 2021Guru - Experienced User
Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 1
Try disabling AX mode on the RBR. Under Basic Tab/Wireless Settings.
