Dazza762
Dec 14, 2021Luminary
Privacy warning on iPhone when on AX4200 WiFi Mesh System (RBK753) network
I've noticed that when looking at the wifi setting on my ios devices that there's now a privacy warning when I'm on my home wifi. The wanring is: This network is blocking encryted DNS traffic. Doe...
- Dec 14, 2021
My internet search for this situation turns up a number of possibilities, including "restart the iPhone".
There are also questions about whether the iPhone is running a VPN and if Parental Controls are enabled on the iPhone or router.
I know of no 'setting' on an Orbi router that needs to be changed.
Regular DNS uses port 53. Encrypted DNS uses either port 443 or 853 (there are two versions of encrypted DNS). Orbi does not block any of these ports.
Dazza762
No. Privtae wifi address on iphone is enabled and I'm using WPA2-PSK [AES] security setting on the RBR
CrimpOn
Dec 14, 2021Guru - Experienced User
- Dazza762Dec 14, 2021Luminary
CrimpOn wrote:My internet search for this situation turns up a number of possibilities, including "restart the iPhone".
No VPN running on the phone when I'm on my home network and no parental controls. A restart of the iOS devices seems to have sorted it. Thanks.
- FURRYe38Dec 14, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- CrimpOnDec 14, 2021Guru - Experienced User
No s**t? The oldest technology solution of all time, and it worked!!!
