Biyahero
Mar 03, 2021Apprentice
Pro Support for Home
I purchased an AX4200 RBK753S-100NAS recently (which this system won't let me put in as the Model ???), and as soon as I hooked it up and (finally got it to function) I purchase Pro Support for Home ...
- Mar 04, 2021
I personally don't use Armor or BD. I help test those applications out when requested by NG on occasion. Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
Mar 04, 2021Guru - Experienced User
Good Luck.
Biyahero
Mar 10, 2021Apprentice
FURRYe38 wrote:I personally don't use Armor or BD. I help test those applications out when requested by NG on occasion. Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
Good Luck.
Thank you FURRYe38
- FURRYe38Mar 10, 2021Guru - Experienced User
:smileywink:
