ctdennis
Sep 06, 2020Aspirant
Problem in RBS850 Ethernet backhaul connect to RBR850
It didn't work; tried many times with updated firmware Works fine when using wireless connection
Chuck_M
Sep 07, 2020Mentor
Can you provide more details including model, firmware, any switches in your network, and devices attached?
- ctdennisSep 07, 2020Aspirant
RBR850 > Negear GS105E switch > RBS850 \ Apart from RBS850, the said switch connected a PC and HP M177fw Printer
- Chuck_MSep 07, 2020Mentor
Any Sonos in the network? What other devices?
No Sonos; RBS850 connected a Samsung TV, TV box, Nintendo Switch
- FURRYe38Sep 07, 2020Guru - Experienced User
is your swtich a v1 or v2 model?
You switch is a managed switch. Try disabling any IGMP and green ethernet protocols on this switch.
ctdennis wrote:RBR850 > Negear GS105E switch > RBS850 \ Apart from RBS850, the said switch connected a PC and HP M177fw Printer
